Avatar size restrictions, seem too small?
I've been trying to crop a picture to make it comply,
Maximum dimensions; width: 120 pixels, height: 120 pixels, file size: 9kB.
I just can't seem to get the file size below 12kB at that given size.
I'm wondering if it's a limit of my file allocation size (which is 4kB I think), so maybe I need to get below 8kB before it'll save smaller than 12kB.
Anyway..., can this file size restriction be increased or should I keep on cropping?
Re: Avatar size restrictions, seem too small?
Keep cropping
Try compressing the original image before you crop/resize ....
Nope, just can't do it. Even when it's so small you can hardly make out there's a bike in the picture... it's still 12Kb..
Email the original to me
The only way I managed it was to select 'save for web' in Photoshop as even with a tiny crop and lowest quality it was still too big.
Good luck.
Good luck.
I did mine in paint.net , just cropped , resized then lowered the quality until the size was right to fit
Sorted - Paint.Net managed it.
Interestingly... I adjusted the quality slider down and at 93% the filesize jumped from 12kB to 6Kb, so there has to be some kind of minimum filesize restriction on my system.
You could have just used a black and white picture
ST4
DRZ400e
DRZ400e
The Muppet
- First Name: Mandy
What good for a apple mac ?
sledgehammer and a shallow grave
