Linking TomTom to battery
Kata
First Name: John
Post by Kata »
Hi All,
Bought a Tom Tom 420. Comes with a lead coming from the mount with 2 pins. This is supposed to be plugged into a longer lead that has 2 wires on the end which I guess you have to wire to the battery.
I've already got a lead coming (TM type) from the battery for the battery charger.
Does anyone know of a lead that will convert between the TM type and the TomTom 2 pin socket?
Ta muchly
Re: Linking TomTom to battery
You should be able to find summat here to do what you wanna do i reckon
http://www.vehicle-wiring-products.eu/s ... connectors" onclick="window.open(this.href);return false;
Ruffian
Post by Ruffian »
Realistically if you want it hard wired to the bike it should be done via a relay to prevent battery drain when not being used.
If you know what shape the plug is its easy,
( for example oxford heated grips now use tamiya battery plugs)
And are cheap connectors online
Nigelw6
First Name: Nigel
Post by Nigelw6 »
I have just wired my TT42 on my Tiger to the horn. It only draws power when the ignition is on and otherwise goes to sleep. seemed much easier than running cables all the way back to the battery.
