A little lost with this, what happens after Cannards Well? I'll be up Chippenham area in weekend so could meet you guys there at 11, but would like to know what the plan is!
Kata
Northern meet at Toby Inn, A 37 Whitchurch for a 10.00 leave heading to Cannards for an 11.00 leave.
My section is approx. 65 miles (from Shepton) and will terminate very close to the start.
There will be a fuel stop not far from the start, and lunch about half way.
E & O E
billinom8s wrote: ↑Apr 25th, '18, 19:58
I'll be leaving teignmouth at 8 for a scenic route up to the eagle tavern.
Still aiming to be at the Bowd Inn, Sidmouth for 0900 hrs Si? Might be cutting it fine to get from there to the Eagle Tavern for 0930 hrs, it's around 28 miles. My old Fut might do it of course but you've only got a KTM Just in case you get a wiggle on, I'll be at the Bowd for 0845 hrs. Let me know, 'cos there'll be a certain CBR-mounted A.N.Other with me and I'll need to give him a heads up time-wise.
Ok, tell you what, i'll be at the Bowd for 0815 so leaving Teignmouth 0730.
If it turns out that my tractor and I have company from there i'll adjust departure time to suit
Bear in mind I'll be approaching the Eagle from the other direction and as the mighty 1290 can spin the Earth in third gear 9:30 may come round sooner than expected. Good idea to leave early.
0815 hrs at the Bowd Inn's too early for me, we'd be at the E T by 0900 at that rate . I'll still be on my second slice of toast at 0815, so I'll be at the Bowd at 0845, meet with Paul S and he can demonstrate the new skills he learned at the California Superbike School last Thursday. I'll try to keep up.
Though you old farts got up at 3 and had done a days work by that time.
Looking and sounding good... Haven't kept up with who's where when but will be at the Bowd for 0830.. see y'all there and everybody else where ever when ever has been agreed
