Desperate Dan
Desperate Dan
Post by MellowYellow »
Need a gear lever of this design.
Pivottie thingy on BOTTOM and RH threaded.
Main aperture 18mm.
Robbo87
Re: Desperate Dan
Post by Robbo87 »
Found this in Germany Larry. If you sprechen sie Deutsch at them you may get it for less than the 60.5 Euro they're looking for. Good luck - https://www.triumphworld.de/product_inf ... anguage=en
Re: Desperate Dan
Thanks for the effort P. but I'm not paying that much.
It's the lateral bar (that the foot actually presses) that has broken off.
I'm hoping that someone might be able to weld a new bit on.
As a last resort I will drill a holes and insert a suitable small bolt.
Re: Desperate Dan
Loads of stuff on the net, mostly from the big red C.
Trouble is no sizes and they're all for 'suzuki'. One even has mirrored different pics - one pivot on top one on the bottom for the same item.
Got a reply from one this morning so have bitten the bullet and ordered one. No rush as I can't ride yet.
