Pembury track layout
Look in for Track days + events
Is this the track configuration that would be used on a typical track day, or do they use some of the other bits?
The link at Dibeni Bend would make for a shorter track, there is the possible divert at Esses and the one on the Speed Straight.
scorcher
Re: Pembury track layout
Post by scorcher »
That's the layout they mostly use for bike trackdays. The "new" bit they use sometimes is the bit between the Esses.
Video of the new layout here. It starts coming down the start /finish straight just so you get your bearings...........
https://www.youtube.com/watch?v=3UktJQzt_8Q
Yeh, I see.
Flows pretty nicely doesn't it.
scorcher
Post by scorcher »
The original corner going into the Esses is decieving and will try and push you up on to the new bit of track anyway, so it may work better. I think Shammy has tried both layouts.
I haven't done the new layout yet but have heard good things.
I'll know by xmas if were going to get a llandow/pembrey double header Next year.
It's a fun track to play on, just check the Racing calendar before booking. It's part of the season so you do get people practicing when it's close to a racing date there.
julesh
First Name: julian
Post by julesh »
old layout is much much better without a shadow of doubt
I have not done the new lay out every time that I have gone I normally do the old lay out and have to say although this is quite a basic track ad the facilities are a bit basic. Not to mention how much it is in the arse end of nowhere.....
If you are going I would recommend the Travelodge at Llanelli Central which is normal quite cheap, the rooms are normal travelodge level but there is a pub just round the corner with good food which makes it a good spot and not far from Pembrey
Anyway been there loads of times and happened to record it. Below is the link to one of my vids from September this year.
https://youtu.be/zkuBkqkyXcU
shammy666
Post by shammy666 »
Not ever done the new track layout as the big left is my fave corner there.
Fun little track, dries out quick if it rains and is grippy in the wet.
adeblade
First Name: Adrian
Post by adeblade »
The new layout lost the best corner on the circuit, the long left hander. So it's the old layout for me everytime. I like Pembrey, yes it's facilities are pretty basic but it's a decent track & the phil beavan days are always well run.
