Pothole partial tyre deflation.
Jug
First Name: Rich
Post by Jug »
Just had my first I think.
Hit a pothole towards the end of a ride and the bike felt weird afterwards but I just thought it was me.
Rolled my bike out 2 days later and it was really difficult to turn the bars. Checked the tyre and it had dropped 20psi.
Pumped it back up and it's been fine since..
So watch out for that happening..
Robbo87
First Name: Phil
Re: Pothole partial tyre deflation.
Post by Robbo87 »
Yep, heard this tale before from elsewhere. If the impact was severe enough to partially deflate a tyre, best check the wheel is still straight and true.
Triumph Sprint ST 1050.
Jug
First Name: Rich
Post by Jug »
Will be doing that soon, ABBA stand with front lift to the rescue!
Jug
First Name: Rich
Post by Jug »
Checked the run out by spinning the wheel with a pointer rested against each fork leg. Then gave the wheel a good clean and inspected it for cracks with a bright torch.
All good thankfully.
Good strong wheels on these bikes, Marchesini, very light too.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Did you check both axial (side to side) and radial (up and down/out of round) runouts?
Jug
First Name: Rich
Post by Jug »
ptolemyx wrote: Jul 18th, '21, 09:49 Did you check both axial (side to side) and radial (up and down/out of round) runouts?
I did, but just by eye.
I put a pointer near the edge and watched for any distance change, so was looking to see if the rim edge got closer/further away but also if it moved up/down wrt to the pointer. There was no discernible movement.
the old fairy liquid and water trick in a spray bottle is useful when looking for potential air leaks
Jug
First Name: Rich
Post by Jug »
Mervin wrote: Jul 18th, '21, 11:03 the old fairy liquid and water trick in a spray bottle is useful when looking for potential air leaks
That was going to be my next test if it failed to hold pressure afterwards.
Thankfully it's been holding pressure just fine since so it appears I got away with that one.
Robbo87
First Name: Phil
Post by Robbo87 »
Which of the Jugmobiles was on it's annual airing?
Jug
First Name: Rich
Post by Jug »
My beautiful Superduke 990, which has now been out three times this year already... I'll have you know!
But with the current state of the roads I might well put it away again. :-?
