2021 Ktm690smcr diagnostic tools
MikeZ
First Name: Mike
Post by MikeZ »
I'm fed up with having to take it to a dealer, so I'm looking for a tool to enable me to scan, diagnose, and update the ecu on my Uk 2021 Ktm690smcr. Note this is euro5, tuneecu and icarsoft won't do it all (according to their websites and email feedback).
Critical items to include:
Quickshifter
Service reset
Throttle position setting
ABS bleeding
DTC code read and diagnose/reset
Am I expecting too much? Or should I be expecting a piggyback ecu?
If possible I would also like it to be able to do the same on my Uk 2022 Kawasaki Ninja1000sx but this is not critical so should be considered a nice to have.
I do have obd connector, windows 10 & 11 laptops, android 16 phone.
Anybody have any thoughts?
I intend to keep the bike, so if it's expensive then will just have to trade off costs of workshop visits versus preference for doing all bike stuff myself. Although I have considered just chopping it in for a Jap enduro and converting it to sm because of ease of working with them in comparison to my ktm (both love it & hate it at times).
Tvrv37
First Name: Phil
Re: 2021 Ktm690smcr diagnostic tools
Post by Tvrv37 »
My understanding is that there is not only no software available to domestic customers there is also no software available to the independent trade. To access the ECU a main dealer has to be signed onto the KTM mainframe. Packages that turn on features such as quickshifters and track pack must be purchased by the dealer and the registered with KTM to a specific bike.
I think KTM ECU's can be hacked using Woolich Race Software but that means a trip to the Dyno and Woolich specialist which is also not cheap.
Jug
First Name: Rich
Post by Jug »
Service reset can generally be done without software, it's normally just a sequence of button presses to unlock the service menu.
ABS generally doesn't need diagnostic software either unless you have drained the ABS pump, for normal fluid changes it's not necessary.
MikeZ
First Name: Mike
Post by MikeZ »
Thanks for the comments.
Having spent >40yrs doing my own maintenance and repairs (bar machine shop stuff) it galls me having to pay to do stuff I can do myself.
Service interval reset: yes thanks should have checked that myself.
ABS: I prefer to fully change fluid, but I guess the volume of fluid in the ABS part is small, and I suppose if I find out the correct signal to send I could make something to flush it through if it bothers me that much.
TPS: I have slightly adjusted how I hold throttle hand, I can now get full throttle without having to move hand around the grip hardly at all.
I could go piggyback ECU, but again it's not a cheapskate option. "We" are playing with software options for 690smcr, Aprilia V4 and 660RS and Z1000sx, the KTM is certainly the most painful.
All fun and games with bikes so can't really moan about it.
Jug
First Name: Rich
Post by Jug »
With regards to brake fluid flushing, one thing that was suggested to me is after you have changed the brake fluid to just find some gravel on the road and make the ABS activate.
Should be relatively safe for the rear wheel but the front could be more worrying. :)):
Also while we are talking about changing the brake fluid. Lots of calipers now don't have a separate bleed nipple, it's on the brake line banjo bolt.
That means the fluid doesn't even enter the caliper if the bleed nipple is open.
So the fluid in the caliper doesn't get changed when flushing, you're just flushing the lines and the master. I think this is more an issue with radial calipers.
I think the next time I do mine I'm going to remove the calipers and push the pistons fully in to expel as much old fluid as possible.
MikeZ
First Name: Mike
Post by MikeZ »
"..... remove the calipers and push the pistons fully in to expel as much old fluid as possible...."
Yes I always do that because having cleaned/lubed the pistons, you can feel the condition of the seals as you push the piston back.
