Arse 6, Help needed!!!!
Cheggers
Post by Cheggers »
Well, the on going saga that is getting my s*it box r6 back on the road took a new twist today :cry: :cry: :cry:
After my lowside, the bike turned over once and then the battery died.
Replaced the battery today for a new one, and hey presto the bike doesn't even turn over now :cry: :cry: :cry:
Made sure all the noddy things such as the kill switch wasn't on and the fuses. wern't blown. The lights and the rest of the electrics are working fine.
Any advice or useful suggestions?
(before i start tw*tting it with a hammer :evil: )
Rides - 2008 R1
1980 CB250RS
Drives - Honda Motegi Prelude 2.2 VTEC
Bunny
First Name: Bunny
Post by Bunny »
Have you tried turning it over with no plugs in ?
I worked on a bike after a spill that would not turn over, it had hydraulic locked.
If not, then check for 12v at the starter and solenoid
Whitetrash
Post by Whitetrash »
does it have ignition power??? a fall could break the loom>
But first check the engine is turning over, put it into second and give it a push to make sure it hasnt locked up
I dont blame You.... I think Im a C*nt too!!!!!
some people just push it too far!!!!!!!!
Chewie
Post by Chewie »
I have the same problem at the moment with the GS500 as it hadden been started in a week or so i tried it and it turned over couple of times spluttered and now wont even turn over though all the battery and fuses are okay.
Couldnt be anything to do with the sparkplugs could it?
Bunny
First Name: Bunny
Post by Bunny »
Chewie - depends whether you mean won't turn over or won't fire ??
Plugs won't stop it turning over
Chewie
Post by Chewie »
Thats what i was thinking, but yeah its not turning over everything else seems to be fine.
haven't they got a tilt sensor??? so when the bike goes over after a spil it cuts out? you may need to lower her again to reset the tilt sensor.......just a thought :D
Post by chris_1127 »
did it go down on the sidestand side? check your sidestand switch/wires all OK. . Also, try bumpstarting it (or run a jump-lead directly from the battery + to the starter motor) and see if it starts, see if its the whole ignition system thats gone or just the power to the starter motor
