Rear Suspension set up!
Webber
Post by Webber »
static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
rider sag= is when the rider has sat on the bike and its the distance measured from when the bike is on its own weight and when the rider sits on it (with helmet leathers on)
if you cannot get the correct static sag, its not even worth doing the rider sag as your spring is the incorrect strength.
RAWRacing.co.uk
Blimey
Post by Blimey »
Webber wrote:static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
Now thats better. I understand what you mean now.
Some of us are a bit thick you know :cry:
age
Post by age »
Yep you do fall in the stupid bracket Mark :lol: :lol: :lol:
PS3 name lesnage
its all french to me :oops: :lol:
Blimey
Post by Blimey »
Up yours AGE :evil:
Cheers JAY mate at least i ain't the only one :lol:
Webber
Post by Webber »
im no rocket scientist :lol: .....i just talk testicles
RAWRacing.co.uk
Webber wrote:im no rocket scientist :lol: .....i just talk testicles
:lol: :lol: :lol:
I wish my suspension was adjustable! :(
sonic
Post by sonic »
Funkalicious wrote:I wish my suspension was adjustable! :(
:cry: anythings adjustable with the right tools :lol:
intersting...i might take a look...
Tom
Post by Tom »
yours is probably more adjustable than mine!
I did buy a ZX6 shock for mine, but it turns out it was fudged beyond repair.
Bugger
andrew
Post by andrew »
As far as I know there is any proper suspension on the CBRs but there are still things you can do, e.g.
The probably won't be able to do much with the rear shock but you may at least have a preload adjuster on it to let you set the sag.
If you wanted to make the bike steer quicker you maybe able to raise the forks up through the yokes - although how much you can do this is limited by ground clearance.
With the front you can also adjust preload by putting spacers (a small piece of plastic tubing with the right diameter does nicely) on top of the fork springs.
You can adjust the damping of the forks by using different weights and levels of fork oils in the forks.
Tbh though you're better of concentrating on doing your test and getting a bigger bike.
