You will be needin LUBE and a MIRROR when i have finished with you pal.billinom8s wrote:more like lube
Tryin to remove your bike from your ar*se.
Could be a bit painful if the exhaust's hot...billinom8s wrote:just have to remove the crash bungs first tho lolBlimey wrote:You will be needin LUBE and a MIRROR when i have finished with you pal.billinom8s wrote:more like lube
