Rear Suspension set up!
static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
rider sag= is when the rider has sat on the bike and its the distance measured from when the bike is on its own weight and when the rider sits on it (with helmet leathers on)
if you cannot get the correct static sag, its not even worth doing the rider sag as your spring is the incorrect strength.
RAWRacing.co.uk
RAWRacing.co.uk
Now thats better. I understand what you mean now.Webber wrote:static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
Some of us are a bit thick you know
Blimey wrote:Now thats better. I understand what you mean now.Webber wrote:static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
Yep you do fall in the stupid bracket Mark
PS3 name lesnage
PS3 name lesnage
- Jay
- First Name: Jay
its all french to meBlimey wrote:Now thats better. I understand what you mean now.Webber wrote:static sag = the distance from when the bike is on it own weight, then lifted and measure the difference.
sonic
As far as I know there is any proper suspension on the CBRs but there are still things you can do, e.g.Funkalicious wrote:I wish my suspension was adjustable!
The probably won't be able to do much with the rear shock but you may at least have a preload adjuster on it to let you set the sag.
If you wanted to make the bike steer quicker you maybe able to raise the forks up through the yokes - although how much you can do this is limited by ground clearance.
With the front you can also adjust preload by putting spacers (a small piece of plastic tubing with the right diameter does nicely) on top of the fork springs.
You can adjust the damping of the forks by using different weights and levels of fork oils in the forks.
Tbh though you're better of concentrating on doing your test and getting a bigger bike.
