Lisa is having another go next year , as we all know this years could not happen , put it in your diaries 29th May 2021 bideford quay
Bideford bike show saturday 29th may 2021 with mobile dyno ?
Re: Bideford bike show saturday 29th may 2021 with mobile dyno ?
this sounds like a plan someone has from Faceache
Mobile dyno trailer at the Bideford Bike Show 2021, would you be interested?? 🏍🏍🏍 here are some details of what will be offered on the day.
The dyno is a state of the art dynojet 250i dyno With updated RT Software & is capable of reading up to 750 bhp & 200mph speeds,
At the show I will be offering power runs for a cost of £25 & This will give you an idea if the engines fuelling is running at its optimum For that particular set-up of intake & exhaust/engine modification's & if any gains would be possible with a custom tune on the dyno at a later date using a Dynojet power commander or custom ecu mapping on certain bikes.
I will do a quick safety check to make sure the bike is in a suitable condition to be run on the dyno & if it isn't I will not run it! If you do not want your bike reeved out then please advise & I will only rev it to your set rpm.
There may also be a prize of £50 to £100 on the day depending on how many people I get on the dyno, If it is very popular then I can do £100 prize, results on the day can be printed or emailed over to the customer.
In my diary. Been meaning to get to this show for years. Perhaps a SWB rideout from the sunny south might be had.
