damn !
damn !
WTF??????
Streetmann
- First Name: Craig
Re: damn !
Juggard comes to mind..the Indian word for make do and get on with it
Re: damn !
No words needed
Re: damn !
This is one that came into my garage to be fixed a few years back.
Re: damn !
He's alright, just get the file out and make the notches a bit deeper again
Streetmann
- First Name: Craig
Re: damn !
Blimey wouldn't imagine that sort of damage to a sprocket could be done between MOTs surelybillinom8s wrote: ↑Dec 13th, '20, 08:12 This is one that came into my garage to be fixed a few years back.![]()
Re: damn !
In Superstock they only use cable ties to retain the sprocket carrier.
Main issue is the extra rotational and unsprung weight.
Re: damn !
I recently fitted new heavy duty cush drive rubbers to the Busa and even with red rubber grease the sprocket carrier was such a tight fit I had to compress it in place and hold with cable ties to fit the wheel. Cable ties removed once in place...
Re: damn !
And I worry that I don't have enough chain lube on the chain whilst the bike is in the garage over winter. After seeing this think i need to stop worrying
