Camera fixing!??
50something
- First Name: Kawasaki
Camera fixing!??
Hi
Looking at possibly getting a bullet camera as am joining the Experts at parcMoto this year. I’ve got some track fairings for my bike but would like to attach a camera to it I’ve already chosen the set up but I cannot find any way of attaching a bullet camera to the fairings as a permanent fixture I am led to believe you cannot use suction pads et cetera as it has to be firmly fixed which is fine and I’m not going to take it off! So I’m looking for some way of fixing it which I assume means some sort of bracket which can be screwed to or fixed to the fairing
I’m not going down the go pro route so it has to be a bracket that will take a bullet camera
Re: Camera fixing!??
The bullet cameras usually use a pipe clamp type of mount if they dont have a threaded insert.
Do you have the camera already?
Go pro mounts are cheap and readily available. Can be used easily and the decent 3m sticky pads do work wonders.
Lots of companies now want to see it securely mounted and a additional leash as a fail safe if the mounting does let go.
Sounds like a job for a 3d printer
Here's a 3d complete with lots of corners...
Two of those and you have an Elsie.....the old smoker Tanner, not the old smoker Yamahahaha
Old folk humour confuses me.
Most youngsters are easily confused; it's good practise for if you ever get old.
Like spelling.
It takes practice.
It takes practice.
Back on topic, because I'm interested now on the camera mount.
P.s. si having a 3d printer does make life easy
Yep, thought you might be able to come up with a solution.
I have seen a bullet camera mounted with a P clamp simple and affective and doesn’t look out of place
Still got some old 3d coins tucked away
MV 800rr brutale
MV 800 turismo veloce luso
Ever problem has a solution depending what is asked and or wanted.
Could always ask Roy?
