JIS screwdrivers
JIS screwdrivers
I was amazed to find in a recent discussion with the gang how many long term riders weren't aware that the Phillips/Pozidrive looking screw heads on Jap bikes are actually JIS, Japanese Industry Standard. You really ought to use the correct screwdrivers on these if you want the screw heads to remain undamaged - the right tool for the job. Saying that, I believe some newer Japanese bikes use PZ fittings. However here are links to screwdriver sets on fleabay and a good article on BikeGremlin:-
https://www.ebay.co.uk/itm/193397531585 ... BMosG92M1h
https://bike.bikegremlin.com/10583/phil ... -pozidriv/
Re: JIS screwdrivers
Cheers for the links Herr P
. I'd only recently learned of the JIS screwdriver thing myself.
Proof positive that every SWB rideout day is a school day ๐
And today you actually saw and handled some.
Although aware of diffences between between Phillips and Posidrive , I didn't know about JIS.
For decades I've used Philips screwdrivers in all crosshead screws unless the screws were of the obviously posidrive by applying 75% push in and 25% turn.
The Phillips drivers are years old and dressed a few times but have worked fine using my routine; but after reading the bikegremlin they are going to be junked for a full set of JIS/Posidrve drivers.
Thanks Brian.
Thanks Brian.
Hang on a minute, Roy - did you actually say you're going to junk something?
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Honda NC750X DCT - sold
1981 Suzuki TS185ER - very much not modern
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Been using them for years. I read something about the screwdriver in the Jap tool kits being better than Phillips screwdrivers even though they are cheap and it's because they are JIS.
I find 16 & 24 oz ball pain hammers along with small, medium and large chisels solve most issues
Forgot grinder, Welder and gas torch also
For the technically minded those are "ball pein hammers" as found in most car repair workshops where old fashioned panel beating takes place.
Yeah, you find ball Pain hammering when you grab a handful of front brake without bracing first.
The joys of predictive text & auto spell check on ones phone
