Background.. my 990 is about finished with its front & rear sprockets so I thought I'd measure the chain. The manual quotes the length for 18 links but my digital calipers don't open that far so I recalculated it for 10 links and then measured the chain (under tension) at the pin centres.
10 pins length --- New 142.875 mm --- Limit is 144.304 (which is 1.429 mm or 1% stretch)
Mine is at approx 143.5 mm which is 0.625 mm stretch or 0.44%.
So my quandary is do I spend £41 on just new sprockets to finish off that chain (and maybe expect shorter sprocket life) or £97 for chain & sprockets?
BTW I have no idea how old that current chain is, it could be the original so has about 21,000 miles on it but it is in great condition and has no tight spots (DID chain).
Let the roast begin..
Edit: just checked the worn rear with a magnet and it's an alloy sprocket, so maybe that explains why it seems to have worn out prematurely.
