coolant /de ionised water mix
Red5
Post by Red5 »
Just picking folks knowledge here...
I've just replaced my radiator on the mighty trumpet 675 and have almost refilled with coolant, is there any harm or reason why you shouldn't top up with de ionised water?? Penny pinching and convenient... :D O:-)
Re: coolant /de ionised water mix
By top up do you mean you already have it mostly filling with 50/50 mix?
If so then yes, no problem.
The more water the better it actually is as a coolant but then the anti-freeze protection will drop as will the anti-corrosion protection, but if it's just a small amount it really won't matter much.
Provided you haven't lost too much coolant then it will be fine.
But would want to make sure that there is still a strong enough mix if wherever you store the bike for winter incase of freeze.
Guest user
Like wot they said. You really don't want to get the mixture much less than 50/50. I keep a 5l container of 50/50 mix in my workshop ready for such use.
Tvrv37
Post by Tvrv37 »
Depends on what coolant you're using as its not a level playing field some are more effective than others. Essentially coolant lowers the freezing temperature, but it also lowers the boiling point making the water less effective at cooling the bike. We are heading to the Spanish desert on what is the hottest year on record for 4 days on track where we will thrash our bikes to death under this extreme heat. I will probably run just deionised water for this and refill with coolant upon my return.
Robbo87
Post by Robbo87 »
There's also an anti corrosion element built in to any coolant so you wouldn't want to dilute it too much for that reason alone.
Red5
Post by Red5 »
Thanks all,
Seems almost unanimous... =))
Yeah, just being tight and not spending on a litre of coolant when I only need about half a litre in a 2.4 litre system. Well within the parameters of 50/50
So, going to top up with deionised H2o...
Thank you all for your responses
Guest user
Waiting for the report on your motor going bang :twisted:
