Sunday 18th August Breakfast ride out
Look in here for local ride outs...
Red5
Post by Red5 »
Ok Guys n Gals, been a while and have checked the forecast and looking to do an early bimble out this Sunday 18th.
Will be an early start from Exeter, rocking on at 0630 from Bridge, maybe a couple hundred miles then back to Exeter, possibly in time for lunch but definitely for coffee and cake back in Exeter early afternoon...
Usual rules of engagement, progressive and competent with no land speed records.
Apart from that no limits. Fuel and coffee stops en route.
Will use the drop off system if numbers necessitate...
See y'all then!!!! :D :-bd \m/ \m/
Re: Sunday 18th August Breakfast ride out
Can't, on a Muddy ride. Have fun.
Guest user
You're fortunate in you won't have me slowing you down as too early. That's why I posted a later ride.
Guest user
If you're thinking of the B3227, Torrington to South Molton the bridge is closed at Umberleigh. The footpath is open so if you have narrow handlebars...
and the B3232 between Torrington and Barnstabubble is closed at Newton Tracey :roll:
