asthmatic kawasaki
samks
asthmatic kawasaki
Post by samks »
hi all,
after some advise on the Kawasaki ZZR1100 D1 (1994). the bike is stock except for exhaust and was running fine for ages, then after a 3000 mile trip around the alps last summer i went to get something from the shops and one the way back it stopped whenever i opened the throttle. so since then i have tried
*the fuel pump
*fuel pump relay
*spark plugs
*fuel
*battery (well fully charge it each time i try it. but new in july)
*checked for tares in the diaphragms
*compression test (all about 100ps on a old leaky gauge)
*fuel treatment (incase of fuel gooing up)
*cleaned all electrical connectors i could find
and still the b****rd will start and idle and purr like a kitten but open the throttle and it just dies and sounds all asthmatic.
other than a match and jerry can what ells can i try.
thanks,
sam.
A_T
Post by A_T »
Have you checked your air filter, that might not be as daft as it sounds, it could be blocked... (and it wasn't on your list) :lol:
RIP [url=http://dcbikers.co.uk/15.html][u]Frank 1960 - 2006[/u][/url] & [url=http://news.bbc.co.uk/sport1/hi/motorsport/motorbikes/1482088.stm][u]JD 1963 - 2001[/u][/url] (always in our thoughts)
ZX6R
Post by ZX6R »
Have you checked all ignition coils as that could be the cause.
It will run fine untill any load is placed upon the spark, thereby breaking down and not firing right.
As you list spark plugs as one of the items check it may pay to get 1 second hand coil and try it.
chris
Nobody with a good car needs to be justified.
Just kwakers
zx6r@southwestbikers.com - Site Moderator
CvPiper
Post by CvPiper »
Coils, or the diaphram in the carb will cause poor running if it has perished.
Total Triumph
Rides:
2014 Triumph Range ;)
07811110200
CvPiper
Post by CvPiper »
Where are you based BTW?
Total Triumph
Rides:
07811110200
Fuel filter, kinked fuel pipe, blocked jets...... do they have throttle position sensors :?
The D1 is carbed isn't it, so it sounds like the transition from idle to needle/main jets ...... have you had the carbs apart :? checked the linkages/cables :?
Have you taken a plug out after it has stopped? is it wet? (so you know it's getting fuel)
Doe's it just stop stone dead or peter out?
Oh, also forgot ...fuel tanke breather and return pipes....
Braai Boy
Post by Braai Boy »
I think Moose is right had the same problem on a mates GSXR and we traced it to an inline fuel filter.
TL1000S Blue with go faster bits...
http://www.racingarage.com
samks
Post by samks »
thanks all for suggestions. it has given me something to work on now. i was thinking my next point was the strip and clean and re-set carbs but i am told the kawasaki is a pain to bleed the cooling system on and the carbs have carb heaters on them and i havent seen anything like it before.
but will check breather and replace fuel filter too.
but any how i will not be looking at it till the next dry/warmish weekend as i have no garage.
as for where am i, exmouth. and the only bike shop i know well enough to trust is steve demen in barnstaple. i just seem to have the worst luck in bike shop's.
age
Post by age »
TLS-Moose wrote:Oh, also forgot ...fuel tanke breather and return pipes....
Bugger I was going to say the same thing :( :lol: :lol:
PS3 name lesnage
samks
Post by samks »
dont you just hate it when that happens. :lol:
samks
Post by samks »
thanks all. i finaly got around to fixing it and it was mud in the carbs. about 2 tee spoons in each float bowl. it was dead easy to do, no harder than bikes with out the carb icing kit on them. i dont know why i just did'nt just strip the carbs in the first place.
any how thanks again.
sam.
