fuel/air mixture
Mark-Blade
fuel/air mixture
Post by Mark-Blade »
Anyone adjusted this on a Blade before??
[img]http://usera.imagecave.com/Mark-Blade/markbladesigcopy2.jpg[/img]
"Without wings, you can't fly"
chris_1127
Post by chris_1127 »
not on a blade, but spent weeks pissing about with the mixture on my gsxr, doing a stage 3 tune on k+n pod filters. dunno if can be of any general help or not?
gsx-aaaaaaaargh!!!
Mark-Blade
Ok Chris, Just found out that there is a colour tune for bikes, been asking about this for a while now, but finaly found one in Halfords :roll:
Were you mixture screws protected ie tamperproofed?
I havn't even looked at mine yet, but I want to set up (or at least check) the mixture is ok before synchronizing the carbs.
chris_1127
no, the tamper restrictor covers had been taken off mine. theyre only little tin plugs that cover the pilot mixture screw anyway, theyre easy ehough to drill out if you have the carbs off. one of them drills with the point in the middle and sharp edges are the best to get em out with.
what carbs is it that the blade uses? should be easy enough to get a pic online somewhere to identify them - on my mikuni bst36's they are underneath on the inlet side of the float bowls, kinda between the bowl and the bit that goes in the inlet rubber
gsx-aaaaaaaargh!!!
Mark-Blade
Bikes not with me atm, I'm at work, but the good ole Haynes is... they are Keihin's CV 38mm, VP88A. The drill bit you describe sounds like a wood drill? Do you reakon it's possible to get the covers off with the carbs in situ? using a small screwdriver etc?
chris_1127
depends how much room you have between the top of the casings and the bottom of the carbs, you might be able to do it with a small watchmakers screwdriver and a mirror. i have a feeling it may just be US and other overseas models that have the plugs though so you may not even need to
gsx-aaaaaaaargh!!!
Mark-Blade
Ok matey thanks, I'll have a look this evening, fingers crossed, I wont have to take the carbs off. :wink:
sprocket
Location: If ya sees me ya sees me | Cracked Silver K2SV650S
Post by sprocket »
Just wondering, how much did you pay for your colur tune, i've been after one for a while too. What temp and revs does it work up to?
[b][size=200][color=RED]DID A WET LAP AT NURBURG[/color][/size][/b]
Is it a bird? Is it a plane? No its a sprocket!!
chris_1127
what size are your plugs sprocket? if its same size as the gsxr welcome to borrow mine. i can let u have it when you let me have the eze-bleed back ;) engine needs to be hot but its only really useful for doing the pilot settings and part throttle
gsx-aaaaaaaargh!!!
sprocket
Post by sprocket »
hehe cheers, not sure what size plugs mine are :| will check using NGK CR8Es if that helps?
