clutch problem
jonoono69
clutch problem
Post by jonoono69 »
Help!!!!!!!!!!!!!!!!!!
Adjusted the clutch nut screw, just above the gear changer to make the clutch bite a bit better on a gsf600 bandit.
Now i have no clutch drive.
change it back to were it was set, but still no different.
Any ideas.
:oops: :oops: :oops: :oops:
[img]http://www.southwestbikers.com/images/sigs/jonoono69.jpg[/img]
:D jono
svr-ash
Post by svr-ash »
Read the manual :lol:
On the SV, there's a clutch actuator which needs adjusting before you adjust anything else, tighten the rest up before and you get the same problem
Have a look in the manual to see if its the same sort of deal :wink:
chris_1127
Post by chris_1127 »
do you mean the cable adjuster or something else? also do you mean not engaging or not disengaging the drive? can you still feel the resistance of the springs when you pull it in?
gsx-aaaaaaaargh!!!
jonoono69
Post by jonoono69 »
:oops: :oops:
No manual for it yet.
its her in doors bike. :oops:
:D jono
svr-ash
Post by svr-ash »
Have a look for one on a bandit forumor similar, theres bound to be one online somewere :wink:
jonoono69
Post by jonoono69 »
chris_1127 wrote:do you mean the cable adjuster or something else? also do you mean not engaging or not disengaging the drive? can you still feel the resistance of the springs when you pull it in?
not disengaging the drive.
its the nut behind the rubber inspection cover for the clutch pressure plate
i think. :oops:
:D jono
chris_1127
ah gotcha. not played with one of them before. the link below seems to be on about the same thing though...
http://www.suzukiownersclub.co.uk/forum ... 8&get=last
gsx-aaaaaaaargh!!!
jonoono69
Post by jonoono69 »
when i pull the clutch in and put it in gear, it stalls,
left in gear, and turning the bike over, it drags on the gears ,
just as you would when turning a car on the starter motor in gear.
:D jono
chris_1127
wind your cable adjusters out, see if that helps, if so unwind em again then adjust the screw in more on the pushrod.
gsx-aaaaaaaargh!!!
jonoono69
Post by jonoono69 »
still no change.
thanks for all your help though. :wink: :wink:
:D jono
Blimey
Post by Blimey »
Jonno where you adjusted the cable it sits in a metal like sleeve which comes out the G,Box yeah. When you pull in the clutch lever does this pull the the metal sleeve with it??
If so does it pull it as far as it can?? To its limit??
Try and push it further and see if it moves. If you have a paddock stand try turning the back wheel with it in gear and see if it is realising the drive.
If it ain't pulling it to its max then cable needs adjusting but remember it has to realease it fully to.
If its pulling it to its max but not disengaging the drive then shoulds more internal with clutch problem.
Kerrie
Post by Kerrie »
He broke my bike :cry: :cry: :cry:
But its ok Dave has come round to fix it now with his trusty supply of cable ties and gaffa tape :?
If Barbie is so popular, why do you have to buy her friends?
Maver-Nick
Post by Maver-Nick »
You got problems with what Kerrie... :shock:
Oh, CLUTCH... I did wonder what Dave was gonna gaffer tape... :wink: :lol:
