clutch problem
Posted: Feb 26th, '07, 19:16
by jonoono69
Help!!!!!!!!!!!!!!!!!!
Adjusted the clutch nut screw, just above the gear changer to make the clutch bite a bit better on a
gsf600 bandit.
Now i have
no clutch drive.
change it back to were it was set, but still no different.
Any ideas.
Posted: Feb 26th, '07, 19:29
by svr-ash
Read the manual
On the SV, there's a clutch actuator which needs adjusting before you adjust anything else, tighten the rest up before and you get the same problem
Have a look in the manual to see if its the same sort of deal
Posted: Feb 26th, '07, 19:30
by chris_1127
do you mean the cable adjuster or something else? also do you mean not engaging or not disengaging the drive? can you still feel the resistance of the springs when you pull it in?
Posted: Feb 26th, '07, 19:32
by jonoono69
No manual for it yet.
its her in doors bike.
Posted: Feb 26th, '07, 19:35
by svr-ash
Have a look for one on a bandit forumor similar, theres bound to be one online somewere
by jonoono69
chris_1127 wrote:do you mean the cable adjuster or something else? also do you mean not engaging or not disengaging the drive? can you still feel the resistance of the springs when you pull it in?
not disengaging the drive.
its the nut behind the rubber inspection cover for the clutch pressure plate
i think.
Posted: Feb 26th, '07, 19:38
by chris_1127
ah gotcha. not played with one of them before. the link below seems to be on about the same thing though...
http://www.suzukiownersclub.co.uk/forum ... 8&get=last
Posted: Feb 26th, '07, 19:41
by jonoono69
when i pull the clutch in and put it in gear, it stalls,
left in gear, and turning the bike over, it drags on the gears ,
just as you would when turning a car on the starter motor in gear.
Posted: Feb 26th, '07, 19:43
by chris_1127
wind your cable adjusters out, see if that helps, if so unwind em again then adjust the screw in more on the pushrod.
Posted: Feb 26th, '07, 20:14
by jonoono69
still no change.
thanks for all your help though.
Posted: Feb 26th, '07, 20:26
by Blimey
Jonno where you adjusted the cable it sits in a metal like sleeve which comes out the G,Box yeah. When you pull in the clutch lever does this pull the the metal sleeve with it??
If so does it pull it as far as it can?? To its limit??
Try and push it further and see if it moves. If you have a paddock stand try turning the back wheel with it in gear and see if it is realising the drive.
If it ain't pulling it to its max then cable needs adjusting but remember it has to realease it fully to.
If its pulling it to its max but not disengaging the drive then shoulds more internal with clutch problem.
Posted: Feb 26th, '07, 21:38
by Kerrie
Posted: Feb 26th, '07, 22:15
by Maver-Nick
You got problems with what Kerrie...
Oh, CLUTCH... I did wonder what Dave was gonna gaffer tape...
