..first problem...lock wouldnt undo, just wudnt budge ! Bent the first key almost right around trying...phoned work to let them know i would be late ! Then. half an hour later, so olive oil (have no normal oil - only lubricant i could find), and 2 f*cked keys, it finally opened. Already 10 mins late for work at this point !
Pop inside quickly to wasj off both sets of keys (they got covered in oil), and the alarm fobs are attached to the keys...no i thought 'o yeah, bike stuff is designed to take a little weather', so didnt think twice about popping them under the tap for a few seconds.
Start up the bike, ride into town, and park the bike up. Get off, and go to blip the alarm to put it on...no blip. Tryed a few more times and it wudnt budge - figured i must have f*cked the alarm fob...not thinking much of this, only a little annoyed at my own silly mistake, i walk to work.
I work my 4 hour shift...while at work, i opened up the alarm fob to dry it out, thinking this would fix it...
I then walk back to my bike...knowing the alarm isnt set i dont bother to blip it. Pop the key in the ignition to turn the bike on...now with this alarm, when the ignition is turned out, you have like 5 secosn to press the alarm fob to disarm the immobiliser...pressed the button. Went to start the bike - nothing. Tried a few more times...still nothing !
O f*ck !!
So..i begin the long walk home, about 3 miles. Its half 11 when i get home. My kind house mate comes in to the kitchen to see what im p**sed off about, i tell him...
Then i go grab the spare alarm fob, and he drives me back down to where my bike is parked...i try it - nothing. Then i open it up and realise theres no battery - so i get the battery from the old one, and pop that in. Try it again...nothing.
O FOR f*ckS SAKE !!!
So...we pop home again - i get out the alarm manual...quick read on what the 'emergeny code' is, and how to pop that in in you loose the fob...then a quick read on 'realingin' the fobs with the alarm.
Pop back down in the car...and manage to realing the fob and it works again !
THANK GOD !
So, 2 hours later than i should be, a little p**sed off, but a lesson well learnt, im finaly home !
But good to know it works i guess !
