Spring is in the air (Sunday 7th March)
- Redlight
- First Name: Tony
Anyone up for a blast this Sunday.......the weather looks good!
Heading south from Exeter (Mc Donalds 9am for 9.30 off, with a mix of windy and fastish roads.
Tea and warm up a Capn Jacks.
Chips in Bude
Coffee at bridge.
Chips in Bude
Coffee at bridge.
[img]http://www.rsvzone.com/forums/image.php?type=sigpic&userid=2104&dateline=1240582376[/img]
- Redlight
- First Name: Tony
Re: Spring is in the air (Sunday 7th March)
http://maps.google.co.uk/maps?f=d&sourc ... 348083&z=9Redlight wrote:Anyone up for a blast this Sunday.......the weather looks good!
Chips in Bude
Coffee at bridge.
kicker2508
- First Name: tom
yep im up fpr this free weekend
Bikes i've owned: mobeltte----->ts50------->gs400------> r6 ------->bandit 400 --------> cb250--------> kx125
Bikes i own: dt 125 field bike ------ gsxr 750
sounds fun, sucks that i am gonna be at work tho
- rik
- First Name: ktm
Sorry mate i would be up for it but am out on sat for a few hours as i am working on sunday.
Have a good one
E-BIKE RETAILER
- Sixth Gear
Looks like a quite a long run. The bike would love to come, it hasn't had a good thrashing since I was last out with you guys back in October. I've got tooth ache, (dentist Monday) Kidney ache, (had an ultrasound a couple weeks ago, found nothing) and back ache. (not a clue why, I hurt it a few months back gardening
it got better and now got bad all by itself) But the weathers been so nice today I'm tempted to take some Ibuprofen and drag myself along. Might be a case of seeing how I'm feeling on Sunday morning. Roll on Spring!
Cheese Monkey
Might meet you at Jaspers
What sorta time you looking at getting there?
- delvey91
- First Name: JACK
Cant confirm yet but looks like a good route! will see you sun if all goes well!
2011 Yamaha WR450F
2004 CCM 404DS
2004 CCM 404DS
- Redlight
- First Name: Tony
Captn Jacks about 10.30.....a quick cuppa then leave about 11ish. Just ballpark times.Cheese Monkey wrote:Might meet you at JaspersWhat sorta time you looking at getting there?
Cheese Monkey
Sweet, I'll get there for about then
- Sixth Gear
Hi Tony,
I figured you'd all be dying to here how I'm getting along. My backs getting better, and tooth aches no worse, so my body can do it, but now the bikes having second thoughts. I thought I'd go out and start it this afternoon just to make sure it's OK, and nothing. So I whipped out the air filter, sprayed in some Easy Start still nothing. Checked the fuel tank and crank case breather pipes, clear. Took out one of my 2 spark plugs, gave it a clean, checked it for spark and there was plenty. Put the plug back squirted in some more Easy Start and it just fired up. Interestingly a lot of throttle while it was firing would kill the engine. Anyway ran it for 5 mins in the garage then took it for a spin round the block and it ran fine. I guessing it's stale fuel as I don't think I've refuelled since October, might be a combination of things, slightly dirty spark plugs, slight waxing up of the carbs after months of being idle. It's also done 28,000 miles so due for valve clearance adjusting, and carb balancing. (I don't suppose anyone has a balancing kit?) Anyway I plan to be there in the morning if the bike will start, if I can use up the stale fuel, and put in some fresh I'm hoping that will fix it. My mobile numbers below if you wanted to add it to your phone, and then if you don't see me and wondering whether I've managed to get the thing started, you could give me a text/call?
Well hoping to be there tomorrow, long time no see.
Andy.
Andy.
Rsv4Col
- First Name: Colin
I will pop down for a coffee but not coming out for the ride
ChrisK5 has a problem with a sump plug that has no threads left and needs sorting before friday so i will be getting the girl washed and readied for friday
Now riding a Tuono V4 1100 😀
- Redlight
- First Name: Tony
Will be good to see you........Chris is leaving it a bit late!!!! Not heard of Araldite?Colin wrote:I will pop down for a coffee but not coming out for the ride
- Redlight
- First Name: Tony
Make sure you have AA or RAC.......I'm not towing you.Sixth Gear wrote:Hi Tony,
Andy.
Rsv4Col
- First Name: Colin
He did an oil change at home earlier in the week and didn't like the feel he was getting when tightening the plug so took it down to Peak performance this morning for a second opinion left there with oil dripping all the way home so now he has to drain the oil remove the fairings and get the sump helicoiled
