street fighter gsxr ish
What do you need to to mount renthrals on gsxr forks ? Ta
Re: street fighter gsxr ish
A drill or some other method of making (accurate) holes in aluminium
a pair of handlebars
longer brake hose from mastercylinder (maybe)
longer clutch cable if you have one (maybe)
longer throttle cables (maybe)
longer choke cable if you have one (maybe)
depending on the bike you may need to extend or re-route the handlebar switch wires
depending on the bike you may need to change the brake (and clutch if applicable) master cylinders if they are units with the reservoirs "cast-in" and designed for clip-ons
The maybe's are there because in some cases you can get away with re-routing the existing ones, depending on the bike and the proposed height of the risers and bars.
Thats easy enough got bars just need risers next cheers Mr Moose .
