HID Conversions
ZX6Rich
HID Conversions
Post by ZX6Rich »
Anyone done one? Can I run a lower wattage on the dipped daytime beam and a higher on my main beam? Ones im looking at come in 35 & 55 watt options...advice from any1 that's done one or at least had experience of fitting one or even thinks they no what they would be doing appreciated :)
Formally Joker1067
Re: HID Conversions
no experience with HID conversions, but I would suggest you dont want too great a difference between main and dipped beams :wink:
I used to run 55/100 watt bulbs, and going from main back to dipped beam was like someone turned the lights out :oops: this is exacerbated if dipped beam is poor ....... I would suggest getting the most powerfull beams you can :wink:
bambam
First Name: Jon
Re: HID Conversions
Post by bambam »
Have you considered fitting some better bulbs??
i am gonna get some better normal bulbs for the zx.
i have some osram nightbreaker ones on the car so will be getting some similar for the bike.they give out a more whiter light and are brighter than standard.
Stikley
First Name: Nik
Re: HID Conversions
Post by Stikley »
Just put uprated bulbs in the bike, same watts at first, you only need to change the lights if the beam pattern is no good. Is this on the Ninja? I'm guessing it is because the SV is not having any mods....
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
meganall
Re: HID Conversions
Post by meganall »
i fitted a 6000k to my zzr easy peasy m8 and makes a great difference at night, just need power from the battery to the ballast etc then plug and play :-bd
KEVW666
First Name: KEV
Re: HID Conversions
Post by KEVW666 »
Hi rich,
I have fitted dip beam hid to my blackbird and dip and main beam to my rr it is very easy i do not have a problem giving you a hand if you need it. :-bd
