Honda C90
Honda C90
I have just tied starting my C90 after it has been sat out side 6 months, all starts fine but my lights, indicators, horn are not working, so I bought a new battery and changed the fuse on the live battery lead, but still nothing is working.
Is there any other fuses anywhere, that I have missed??
thanks
thanks
Re: Honda C90
I am probably in danger of being involved in a wind-up, but anyway;
The C90 only has one fuse. I would think C90club.co.uk. is your best bet for wiring etc.
Re: Honda C90
Thanks for that
I could only see one fuse, but I have no idea why the electrics are not working, when they were perfectly fine. I even put a new battery on first, she starts no problem, not even the horn works
Thanks for the link
Thanks for the link
Re: Honda C90
what year c90 is it?
Re: Honda C90
The following link gives the full explanation of the wiring. You will read that it is not the battery.
http://www.c90club.co.uk/Guides/Honda%20Electrics.html" onclick="window.open(this.href);return false;
ninjajockey
Re: Honda C90
is it 6 or 12 volt? and did you get the right battery?
Re: Honda C90
Its a 1977 and is 6 volts
There are three boxes on the side above the battery
1 is an aluminum box with wires coming out of them and the other 2 are sealed boxes all no bigger than 1-1/2 by 1 inch
Even the horn and brake light are not working
I cannot see anything wrong with the connections or fuse.
Re: Honda C90
Did you try to start it with the knackered battery? If so may have blown the bulbs without the the battery absorbing the voltage sent by the generator.
Have you checked the bulbs?
I think the C90 differed to the C70 as far as electics were concerned, I think the 50/70s would power the lights straight from the generator whereas the C90 used to power them from the battery, again make sure the new batter is OK/connected correctly.
Re: Honda C90
Dizzy,
if you go to the introduce yourself section, say hi and let people know where you are, there may be someone close that could come and give you a hand,
MW2K8
- First Name: Matt
Re: Honda C90
The wiring behind the headlight is a nightmare, i've lost count the number of times i've had the headlight off buggering about with connectors etc on my 90
C90club.co.uk is a great shout, or check out the facebook group, plenty folks on there to help you out
XR400 for sale soon...
