The rear works but only when I've compressed the break quite far so I may adjust this, the front doesn't make it come on at all
Where can I locate the front brake light switch On the zxr400 if anyone's aware
Any advice
I'd imagine I'm looking around the brake lever itself but can really identify anything
The story goes on... Now front brake light
Re: The story goes on... Now front brake light
Small box normally on underside of lever housing. As you pull lever you should hear a click. That's the micro switch. Check the connections but they do fail sometimes.
