EXPENSIVE ouchie
EXPENSIVE ouchie
https://youtu.be/rNWf0nCl6ns" onclick="window.open(this.href);return false;
Re: EXPENSIVE ouchie
Nothing like a solid bullet proof engine
Usually rob I would agree with you but if you read up on who's engine it is, then I don't think that saying would stand,menzies3032 wrote:Nothing like a solid bullet proof engine
If you read the video discription it shows that this h2 has been modified to push out over 300bhp on standard internals and been drag raced a lot and raced over the standing mile a lot. All this with overy 10k miles on the clock and still on its factory build.
Yes it did spit a rod through the casing quite spectacularly but then mostly every engine running 24psi of boost wouldn eventually.
https://youtu.be/CL4dfV4gUn0" onclick="window.open(this.href);return false;
His other video showing what it usually does
