2 years of restriction is over!!!
Banditmax
Re: 2 years of restriction is over!!!
Yeah you definately have to remove the carbs then.
hazard9
IF THE RESTRICTORS ARE IN THE CARB RUBBERS THE ENGINE SIDE OF THE CARBS LEVER THEM OUT WITH A SCREW DRIVER TAKE CARE NOT TO SPLIT YA RUBBERS THEY WILL BE QUITE TIGHT...
PEOPLE SOME TIMES SMOOTH THE INSIDE OF THESE RUBBERS BELIVING IT IS A PERFORMANCE GAIN...
LIKE GETTING A POLISHED AND PORTED HEAD I SUPPOSE.. BETTER DISTRIBUTION OF FUEL..
THERE SHOULD BE NO METAL INSIDE THE RUBERS DEPENDING ON MAKE AN MODEL...
well im trying to organise a cornish rideout on saturday as im going to plymouth for daddy's bday on sunday, but so far not an amazing amount of interest so would more than happy to make a solo run to looe on the saturday iof thats what your thinking?
secretlegend05
Thanks guys and thanks Dayz. Ill have a look at what i can do with whats been said... I may be able to get it done and save you a trip mate... But I really am interested in any rides you guys have. Tho being new to the whole 33+bhp i will be taking it slowish
Ill have a play first thing 2moro morning and see what happens:D
okay then, i dont mind the travel at all, i was planning on going out anyway
just lemme know fri night or early sat morning, im not fussed, good luck anywho
