donington park trackdays
here is a copy of todays email newsletter from focused events regarding donington and when its closing for refurbishment :oops: :oops: :oops:
Our Final Donington Park Trackday of 2009
Donington Park closes for its revamp mid September. Our final trackday on its existing layout is on September the 10th.
Donington Park changes for ever to its new F1 designed configuration from mid September. This will combine a major transformation of both track layout and facilities and requires a huge amount of work and time.
The 10th of September will be your last chance to ride it with us in its existing layout. It will be in our standard three group format with a 105db noise limit. £159
This is your last chance to ride the same laps as so many legendary riders over the years. Another page is turning in the Donington Park history book and you can be part of it.
In terms of track development, the redesigned Donington Park will represent an equal mix of old and new. The designer, Tilke, has been careful to ensure that the additional sections of the track will complement the historic layout. The northern passage from Redgate Corner to McLean's Corner will remain unchanged. However, Coppice Corner is to be realigned and Starkey's Hill Straight and Melbourne Corner will be completely restructured.
From Melbourne, the track runs downhill into the new arena, using the current 4x4 track to create an exciting loop, which will achieve the required increase in length. After a sharp left, a slight right and an almost 90-degree right turn, the track will climb uphill at a challenging 12 per cent slope before leading back into the existing track formation. This undulation creates an exciting challenge and provides plenty of possibilities for overtaking and outstanding spectator viewing opportunities.
Maver-Nick
Re: donington park trackdays
Post by Maver-Nick »
You going Dave ???
Rsv4Col
First Name: Colin
Post by Rsv4Col »
We were supposed to be at donington on the 26th but now cancelled so doing rockingham on Sunday 27th instead only £139 and 105db (( Leroy would get 10% off if he went ) Gixerjunkies discount )
Now riding a Tuono V4 1100 😀
Maver-Nick wrote:You going Dave ???
no matey,just got the email through and knew a few others were booked later in the month ala colin
i mkight be going cadwell in october with the sp boys,its on a sunday and only 99quid
