Ive been advised to change from the diaphram spring to the 6 coil spring type, does anyone else suggest this?
Also whats the best clutch plates to go for, been looking at ebc and barnett ones, and is it recomended to change the friction and metal plates? or is it worth just changing the friction plates.
ive had my clutch out and the plates have loads of life left in them so im unsure why its slipping,
anyone had this problem? im a tad confused and what ive typed above may be abit hard to make sense off
basically the clutch is slipping, whats the best idea for replacing it, it needs to be able to take some abuse
