Badger had a ride...
Smiler
Rideout Ringleader
Post by Smiler »
on a Special Yellow Lorry.....?
c'mon, fess up....what happened? :)):
(hope you're ok mate xx)
Smiler
Re: Badger had a ride...
Skip lorries are yellow around here ......... :lol
our recycle bin cleaner lorry is yellow
So there I am, cruising home early monday morning, when I loose drive at the back wheel????
Clutch in, negotiate several lorries to get to hard shoulder and back end locks up as i stop, wtf????
Turns out the nut holding my front sprocket on has decided to go walkabout, with the sprocket shuffling off the splind shortly after :(
Luckily no major damage, and the sproket was trapped in the front chain cover, but the nut was long gone....
was given the option of being taken to a bike shop at South Petherton who MIGHT have a nut to fit? I only have roadside so i would have still been stuck there if the bike shop couldn't help, so I took the expensive option and upgraded to relay cover, £109 later I'm sat in a truck on my way back to Redruth :-o
So, one new Lock nut later, everything is back to normal but my wallet is one hell of alot lighter #-o
The worst part about it, for the last 3 yrs everytime I'v changed my chain and sprockets, the front sprocket nut has had to be undone with a air powered impact driver, even a very long bar has failed to shift it, and we've always done it up with the same impact driver and tab washer to lock it, so how the f**k did the nut just decide to undo itself :-\ :-\
By the way, how is your bike Sheila? Did the problem persist on the way home or did it fix itself?
Smiler
Rideout Ringleader
Post by Smiler »
Oh noooooo!!!!!! :( Sounds like you were lucky not to come off!
Lottie is gonna get looked at later this week, but I'm fairly confident it isnt anything too serious ~ hope you get your bike fixed up soon xx
Sorry to hear of your mis-fortune......
Did you use thread lock the last time you replaced your front sprocket?
At leats no damage was done......Well only to your wallet.
'tis a bloody crap method Suzuki persist in using - just one effing big nut - why can't they follow others lead and have a retainer that bolts to the sprocket :roll:
Glad you're OK though badger :D
graham22
Post by graham22 »
badgerKDD no - badgerRAC :))
OK, I know the RAC trucks are not yellow but BadgerAA would sound like he has another problem. hic
My TDR did the same last autumn on the road to moretonhampstead,the tab washer broke,luckily we found the nut and sprocket in the road and the remains of the tab washer, the shock adjuster spanner un de the seat fitted the nut tightened it up used a screwdriver and a stone managed to knock a bit of the tab washer over and got home ok, but i will always fit new tab washers now , also there was a spacer that moved and let oil piss out, luckily there was a guy with a bloody great adventure bike with us that had some oil in his panniers to top it up with
Interestingly i couldn't buy the tab washer as Suzuki have discontinued them :-\ , they now sell a pre lock-tighted locking nut instead. Methinks its not un common for the tab washer to break...........
Anyway all sorted now and rode to work as normal this morning :D
Oh and Graham, the rumours of my alcoholism are not true, its only to offset the coffee overdose ;) ~o) ~o) ~o) :)) :)) :))
Red5
Post by Red5 »
WTF... Gald all ok though. At least you're relayed up now, which means you can afford to break down again in the next 12 months. Hmm, not funny... :erm:
Catch you soon buddy.
Porkins
Bad luck mate, at least it wasn't a yellow bus.
Funky wrote:Bad luck mate, at least it wasn't a yellow bus.
