I have hated the thick seat padding on my R1 track bike from day 1, so far have tried twice to sort a nice looking place to put my backside and think I have now finally done it......found myself a suitable piece of metal sheet and fabricated it into the base that you see in the pic. Now I can just stick on a nicely cut piece of HD foam and it's done and will look pretty good I think and will no longer resemble an armchair. The HD foam will completely cover the base. Had to do it this way as the seat unit for the R6 has the middle missing which is usually covered by the bulky sub seat.
Will post a pic of the finished article once I have the HD foam which is coming from eBay
good thinking, just make sure the battery terminals are insulated from that sheet of metal.
don't forget we are onX and Instagrambelieve it or not !!! southwestbikers@southwestbikers (original, I know.
KTM 1290 SDR KTM 690 supermoto smc R, Zx10r trackbike,
Give me a shout if you need any advice or such like, its my field of expertise. I've just repaired Graham's X7 seat base using fiberglass as the steel was too thin and fragile to be welded.
badgerKDD wrote:Give me a shout if you need any advice or such like, its my field of expertise. I've just repaired Graham's X7 seat base using fiberglass as the steel was too thin and fragile to be welded.
