HELP NEEDED
speedy(delboy)
Post by speedy(delboy) »
or this one :?:
cgi.ebay.co.uk
Whitetrash
Post by Whitetrash »
Hmmmmmmmmmmmmm Dubious really, avoid the second one as its alreay been cut and you cant prove its strenth.
First one possibly suitable but my advice to you would be to find the year of the tail section you like and stick to buiyng all the bits from there.
Contact Suzuki and find out part numbers, what year (If Any) The subframes were changed or modified in anyway... the more you know, the easier its going to be.
I dont blame You.... I think Im a C*nt too!!!!!
some people just push it too far!!!!!!!!
CvPiper
Post by CvPiper »
You don't want that first auction as its off an old cradle frame 1100 style bike. Need a spare SRAD on to piss about with, or a K series to either mess with or just compare to yours.
Is there anyone who can get a microfiche of both generation subframes?
And the other thing, are you totally happy carrying a pilllion on something that has been altered, its a lot of weight on the connections to the main frame and you don't want it to give way.
Total Triumph
Rides:
2014 Triumph Range ;)
07811110200
CvPiper
Post by CvPiper »
Total Triumph
Rides:
07811110200
Whitetrash
as long as its been properly welded and strengthened then it should be able to carry weight fine, no point getting an SRAD subframe... too much work to alter.
CvPiper
Post by CvPiper »
Was only a idea. I personally would alter the standard frame in a way to take the bodywork. People already use spacers on SRAD frames to get the higher rear you see on more modern bikes.
Then again, I'm not doing it, if anythign I would go for a TL rear ;)
Total Triumph
Rides:
07811110200
Whitetrash
Not having a go Piper.... it just should be easier to mod the K seris frame as its a fair bit smaller compared to the SRAD one!!!
chris_1127
Post by chris_1127 »
http://oldskoolsuzuki.info/index.htm?pa ... x.htm~main
take a look here at another really useful guide to subframe swaps, this one was done on a slingshot frame but the principals gonna be the same. you could always see if cms or somewhere will let you compare a k and a srad subby too.
speedy(delboy)
chris_1127 wrote:http://oldskoolsuzuki.info/index.htm?pa ... x.htm~main
Thats Brill, I do the picture thing, easier than just text.
That is now one mean bike, you can see why I want it done, cant ya :!:
Cheers Chris
