bike died. help needed.
jamieclayton9
First Name: Jamie
Post by jamieclayton9 »
i was riding my 1999 svs home last night and it just cut out. the lights stayed on and all the normal electrics seemed to work. but when i pressed the starter nothing happened at all. i didnt knock the kill switch. there is'nt even a noise comeing from the starter at all. any idea what it could be. help would be much apreciated. many thanks. jamie
Maver-Nick
Post by Maver-Nick »
I spent 2 days charging batteries, jump and bump starting my bike.
The start/stop switch was on stop :oops:
jim
Post by jim »
good job u didnt sell/exchange it :oops: :oops:
07974979311
[img]http://i22.photobucket.com/albums/b301/prkys3/jimsigcopycopysmall.jpg[/img]
Could it be the ignition coil?
mental
Post by mental »
was it p*ssing down ?
Caring, Understanding, Nice, Timid, Serene.[img]http://i19.photobucket.com/albums/b177/mattsvs/46.jpg[/img]
sprocket
Location: If ya sees me ya sees me | Cracked Silver K2SV650S
Post by sprocket »
Yeah water logging was a big problem with a lot of the old SVs. Shame SV650.org is down otherwise you woulda been able to find a lot more information on it. Try svrider.com and have a look on the forums there a lot of the guys from sv650 frequent there too.
[b][size=200][color=RED]DID A WET LAP AT NURBURG[/color][/size][/b]
Is it a bird? Is it a plane? No its a sprocket!!
baskie
Post by baskie »
petrol? im sure u aint dat stupid. but worth checking
boyscout
Post by boyscout »
Sounds like a blown fuse.
jim
Post by jim »
baskie wrote:petrol? im sure u aint dat stupid. but worth checking
didnt know no petrol stops the starter from turning
07974979311
tdmwicky
Post by tdmwicky »
boyscout wrote:Sounds like a blown fuse.
here here.
"whale oil beef hooked"
exiled Oirishman livin' in Sasanna.
hilljd00
First Name: J
Post by hilljd00 »
does the neutral light work? If theirs no neutral light its your main fuse, most likely a 15a.
even if the starter died it wud not of cut your bike out.. Check your plug, and HT lead as well..
If your unlucky could be your coil.
Tom L
Post by Tom L »
it woudln't explain why it cut out but have a look at the electrics behind your starter switch. They went on my last bike, bit of rewiring and it worked fine agian.
hilljd00
First Name: J
Post by hilljd00 »
Can you describe the what happened? because if the plugs really really sh*t high it will cut out.
Bunny
First Name: Bunny
Post by Bunny »
Check the fuses
Bypass any cutouts - sidestand switch / kill switch
Sounds like one of those is cutting your electrics.
Plugs / coil / petrol will not stop the starter from working
jamieclayton9
First Name: Jamie
cheers for all your help chaps. it ended up being the ignition coil fuse. cheers for the help. i am usally a regular user of sv650.org just thought it wouldnt load on my computer for some reason so thanks for that bit of information aswell. cheers. jamie
