ADVICE PLEASE - think the cars fooked!
sonic
Post by sonic »
hope theres someone who knows about cars around...
was driving home and got quite a severe wobble through the steering wheel and a strong pull to the left!!! strong enough wobble to vibrate the car!
checked all nuts are tight etc. and continued with no wobble - thought may be a wheel bearing on its way out?
as i got near home there was a clunk and now whenever i turn right a clanging/banging/clunking noise!!!
have one of the steering rods come loose or something??????????
cheers for your help - hate cars! :x
SNIFFY
Post by SNIFFY »
If its clicking noise when turning this normaly is a CV joint on its way out. Be warned the can just let go and you end up with no drive.
CvPiper
Post by CvPiper »
Could be driveshaft or CV joint I guess mate.
Total Triumph
Rides:
2014 Triumph Range ;)
07811110200
sonic
Post by sonic »
cheers for the quick response - looking at a couple of other sites it does sound like the cv joint.
would that account for the intermittent wobble as well?
any idea what i am looking at to replace it?
tomr6
First Name: Tom
Post by tomr6 »
sonic_gsxr wrote:cheers for the quick response - looking at a couple of other sites it does sound like the cv joint.
Ross, give Ian Anderson a bell on 842231, tell him I recommended him to you (hes my track day partner) and he will be able to sort you out. He is based in Saltash by the fleet club.
sonic
Post by sonic »
will he do it on the cheap then - because cars not worth a great deal :P
BOSS
Post by BOSS »
Sounds like a collapsed wheel bearing :( :(
[img]http://usera.imagecave.com/BOSS/bossbanner.jpg[/img]
When everything is coming your way, you're in the wrong lane.
chris_1127
Post by chris_1127 »
if the cv joint is worn then it would allow the driveshaft to wobble about which would probably account for the occasional wobble you feel through the wheel too. if theres a regular tap in time with the wheel turning on full lock then sounds like this.
grab the driveshaft near the outer cv joint and try wiggling it - you should feel any play there too. Also with the front wheel in the air try rotating the wheel - see how much play there is before the driveshaft itself starts turning. if the joints on the way out the wheel will probably turn a fair bit before the driveshaft moves.
to check your wheel bearing just jack it up and grab the wheel at 6 and 12 o'clock and try rocking it back and forward - you will feel any play quite obviously
gsx-aaaaaaaargh!!!
rnblade
Post by rnblade »
BOSS wrote:Sounds like a collapsed wheel bearing :( :(
thats wot i though mate.
CONSIDERABLY FASTER THAN YOW !!! but only on the track !!
sonic
Post by sonic »
is that worse than the cv joint? :?
chris_1127
wheel bearing is an easier and cheaper job than a cv joint - just got to take the wheel and disc etc off, shouldnt take more than half an hour. cv joint more expensive part plus you have to pop the bottom ball joint to get the driveshaft out usually. jack it up and give the wheel a wiggle - you'll soon see if its that
gsx-aaaaaaaargh!!!
sonic
Post by sonic »
cheers - will give a wiggle when i get home! :P
Gingey
Post by Gingey »
Well mate i would def go with the driveshaft option, but as someone said could well be a collapsed bearing, not a wearing one as this just usually makes a humming noise, bugger hey. :roll:
[img]http://i28.photobucket.com/albums/c227/Gingeyuk666/SIG2.jpg[/img]
Blimey
Post by Blimey »
Some wheel bearings have to pressed out mate. Which do take time :roll:
C V joint only takes seconds after you drop the bottom ball joint.
