Well yesterday i noticed the gear shift was a bit stiff and that it couldn't always find the 1st and 2nd gear, and today ive just gone out to start it and i cant really move the gear shift at all, its like its ceased right up!?
What could this be guys? Cheers all
Gears....what gears!
Gingey
[img]http://i28.photobucket.com/albums/c227/Gingeyuk666/SIG2.jpg[/img]
sonic
hope fully its not as seroius as oil - but might also be worth checking the linkage shift rod has not come loose as this is a 30 second job to fix...
happened to me - i was stuck in first gear, it just would not change up, stopped and noticed, whipped it off and tigthened it - job done...
i hope its that simple for you - but remember this was a suzuki and i know f-all about kwaks...
Gingey
Cheers for the input you guys, but i have sorted it now, also cheers to Andrew as i disturbed his day of rest
It was at the foot peg end of the linkage, so built up with crap from the road it just stuck solid....with a can or so of wd40 and a tub of grease it seems to be fine again, but thanks again all.
